My Tamagotchi is still not working after a battery replacement?
I put a new battery in but it is still not working, so what else can I do so it can work and be played?
Questa è una buona domanda?
The mains problems with tamagotchis are :
Hope it will help someone
My tamagotchi is only 6 months old (the base). I had put a battery in, but it didn’t work still. I had put it in correctly and it still wouldn’t work. I had used a maxell battery
I suggest making sure you inserted the battery in the right direction. I know this sounds like a simple thing, but someone I know did a similar mistake and ended up throwing it away when the solution was so simple.
Maybe reput the battery’s in if not get a box of new battery’s so it will work better 👏👏👏
So this might be a bit obvious, but if your battery has a sticker take it off unless it says otherwise, because I didn't and i spent AGES trying to figure out what was wrong and then my dad came and took the sticker off and then it started working. So yea
Ultime 24 Ore: 3
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 201
Tutti i Tempi: 7,422
3 Commenti
Seriously, what is the gadget you're talking about? Are you sure that the problem is the battery only? Please complete questions so that you'll receive helpful answers.
da blanchell
set it on fire....................................................
da Michael O'Neill
Why won't my tomogotchi work?
da Lilly Allen
