Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Backlight works, but there is no display.
Hello,
I have an iPhone that will not display an image, but the backlight turns on. After inspecting the area around the lcd connector I determined that the L44 display filter was missing. I replaced it with one from an old iPhone 5, but nothing has changed. The phone is still turning on but not displaying an image. When it is plugged into a charger it just beeps periodically. I have tried many different LCD's so I know that is not the problem. I will include a picture of L44 that I replaced.
. This was my first time replacing something this small, so I don't know how good of a job I did. Does anyone have any suggestions for me?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
After replacing a Filter you should always check if you have done a proper job with a simple multimeter. In this case connect the probes of your MM according to the picture I added. It should beep when you connect them. If they don't that means you do not have continuity and the filter mostlikely is bad or not soldered properly. 1 Filter = 2 measurements (each color represents 1 measurement)
While you at it: check the other filters too.
Why was the filter missing ? Waterdamaged board ? ripped of ? maybe there are more components missing the the lcd connector ?
Punteggio 1
1 Commento:
hey i suffer the same problem backlight coming and no image.. and i checked my diodes they give error so i removed them and attached the jumper.. but still no image on display... i also tried new lcd but nthng is there
da
Aggiungi la tua risposta
mSuj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,563
