Engine siezed. Parked then wouldn't start
Engine won't start
Update
Took out starter Turned engine by hand. It won't turn.
Questa è una buona domanda?
Engine won't start
If you absolutely can not turn your engine over (remove the accessory belt and use a breaker bar with the appropriate socket on the crankshaft pulley) than you most likely have some severe engine damage. Not much you can do on a seized engine other than to replace it.
There is starter coil between battery and starter motor, try replacing this.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 197
