Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
cheap charger burnt and phone won't work
I had purchased a cheap chargedr and eft my phone on charge for a few hours and when I checked my phone the wire was completely burnt and my phone just died, it just wouldn't start. I purchased a new original charger and it still wouldn't charge. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
shawtyxxx999 at best your cheap charger destroyed the lightning connector. start by repalcing the connector as well as the battery. Use these guides iPhone 5 for that. If that still does not fix your problem, than you are having issues with the power management IC on the logic board. The repair for that will need sprecial tools and special skills.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,693
