Salta al contenuto principale
La nuova versione del 2013 della serie di Mac fissi conosciuta come Mac Pro.
117 Domande Visualizza tutte
diagnostics led meaning on macpro 2013
i have a macpro 2013, it stop coming up and when i remove the cover, the diagnostic led show now sign of power entering the system at all. and when i press the button beside the strings of led, two came up. what could be wrong? pls help....
thanks
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
The Mac won’t come on without the housing. You will need a magnet. The 2 LEDs that come on when pressing the button only verify that it’s plugged into a power source and getting 12V. Remove the bottom cover, then you will be able to access all diagnostic LEDs. Photo shows what kind of magnet will work and where to hold it to power the Mac on without the housing.
Punteggio 2
1 Commento:
you sure a magnet is needed to open it?
https://it.ifixit.com/Smontaggio/Mac+Pro...
da
Perfect. Thanks! Best regards
Punteggio 0
Aggiungi la tua risposta
olamife sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,384
