Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
Domanda Chiusa
definitiv error 28 or 9
Hello MacFixers :)
I come to you because my iPhone 3G is on DFU mode. I've tried ALL the stuff given by assistance Mac Pages + checked with the hotline…
Once plugged to itunes, I have either an erro 28, or a 9 one… but nothing move...
I have to tell you that it broke down during a thunderstorm, and it was plugged to electricty… hum hum hum…
MY TWO QUESTIONS ///
- Is there any chance to do something ? and turn it back t a regular iPhone ?
- Is there any chance to fix it and make it a simple touch screen, that can be USB connected to an ARDUINO suff for exemple…
THANK YOU ALL !
Ch.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
error 28 can be a logic board problem, but you can als get error 28 whe the battery has a to low voltage.
since it happend during a thunderstorm, it can be anything on the logicboard - fom a simple shot fuse, resistor or anything else.
the only way to find out would be a "checkup" by a professional (no not the people at the genius bar)
Punteggio 2
2 Commenti:
+ Are you sure you tried ALL? There's a lot. Here's Apple's guide to working through your problem: http://support.apple.com/kb/TS1275
da
error 28 is a flash error so you need a logicboard for it
Punteggio 0
1 Commento:
can you give a link for that?
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,939
