I broke my tablet by dropping it. Can someone help me?
I was at a track meet playing on my tablet but then I dropped it on hard soil. Should I get a new one, or can you help me fix it?
Questa è una buona domanda?
can i email you the photos?
Is the screen broken or it just won't turn on or both?
My screen isn't broken, it just won't turn on!
image|642 [124] This is my black screen tablet!
Tablet doesn't have a Crack just lines come on the screen
When I dropped it I had a kid fix it and they said a wire came loose when I dropped it. Then when they fixed it my volume button fell off and I pushed it back in and only the volume up part worked. The other side feeled like nothing was under it and the only thing supporting it was the other side. And then afterwards it just took a dumped on me and it has been lying on my living room floor since for like three months now.
and then it showed nothing but it was acting like only that the screen wouldn't turn on because after I charge it for a while and prees the button like I would if it died, whenever I touched it, it would make a noise
I actually dropped my visual land how can I get it fixed and how much
It got dropped by mistake how can I get it fixed
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 826
Jj Fish, what does your tablet do, or not do? what have you tried?
da oldturkey03
Well, mom told me to plug it in. Then i tried to power it on, so it showed gray for a few seconds, then it would dim for a second. then it would be gray again for a minute. then the screen would turn off. then i tried holding the power and +V. it would be gray with lines and boxes forever. then i decided to hold the power button. i tried this a lot of times and it did not work.
da Jj Fish
It would help if you had a better picture and what kind of tablet it is. Most likely it's fixable but it will take some disassembly.
da Arthur
My step-daughter dropped mine and it hasn't turned on, or taken a charge since. Can I send it in for repair's or do I just need to trash it?
da Dimples Susan Moore
My screen is broken ,, can it be replaced?
da jane1965
Mostra altri 2 commenti
