There is a 10mm bleed zirc like fitting on the thermostat housing tube. When the engine is stone cold, remove the radiator cap, open the bleed screw, top off the radiator with coolant until no bubbles come out of the bleed screw. Close the screw and replace the cap. See if this works.
There are also two speeds to your fan. High and low. Be sure the high speed is working properly. Get a mechanic to test it, or google the procedure. Good luck
Mine would sound like a coffe pot all the time. mine was a burned out fan that would stall once in awhile. Full replace fixed it. But, went through all the other methods I could find as well.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
What happen if you dont bleed cooling system
da Robert Hannon
