Stripes on the screen iPhone 5
Board did change my iPhone 5 and I get stripes on the screen please help
Questa è una buona domanda?
change the logic board, when I put the screen when you get to the menu started to put stripes from top to bottom and then damage the screen after interning several times that work, I put another screen and just step.
cambie el logic board, cuando puse la pantalla cuando llego al menu comenzo a poner rayas de arriba hasta abajo y luego daño la pantalla luego de internar varias veces que funcionara, le puse otra pantalla y paso igual.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 446
Can you elaborate a little more as to what you've done to the phone? Did you replace a logic board on the phone?
da Tony Gines
