Apple Hardware Test Error: 4SNS/C0000008:Ts0P--124
After running Apple Hardware Test I got the error code 4SNS/C0000008:Ts0P--124. Some the symptoms I observe is that the computer runs very slow and the fans are always running at high speed from the moment I start the laptop. Anyone knows what this means?
Update (04/27/2015)
Okay oldturkey03, I posted an image of the inside of my Macbook 13" retina late 2012 in my first post. What's circled in red is the SSD tray that has the solid state drive. What's circled in yellow is where I believe the palm rest temp sensor should be located from reading your description. Please correct me if I'm wrong.
Questa è una buona domanda?
4 Commenti
Use this guide Aggiungere immagini ad una domanda to add images
da oldturkey03
I have the Same issue on the same model. Did you solve it? Is the sensor there in the picture?
da Asher Wood
Yes, that's the board where the sensor is located. It's part of the trackpad. Follow this IFIXIT guide: MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement
da Dan
Ts0P could be:
Trackpad
Trackpad Flex
Camera (in some models)
Trackpad flex connector (logicboard)
da Juan Corredor
