Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
Domanda Chiusa
Optical drive not functioning properly after re-installation
I had replaced my optical drive with an SSD, and put the optical in an external enclosure for awhile. I just re-installed the optical drive and now it doesn't pull a disc in at any other time other than when booting up.
The machine sees the OD, and if a disc is inserted on boot-up it will appear on the desktop. But if you eject that disc and attempt to put another in, nothing happens...the disc will not be pulled into the drive.
Is there some sort of switch that might be out of place? Is there any way to repair? or will I just need to get another OD?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You could always try resetting the optical drive cable(s). If that doesn't help, you could reinstall OS X. It may need to recognize the drive and reconfigure it. My only other thought would be that the drive could have been damaged while it was out of the MacBook Pro.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 49
