Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
3418 Domande Visualizza tutte
iPhone 5 keeps rebooting after water damage
Hope you can help me out, my iPhone fell into the water. After this my iPhone will only boot up when the charger is plugged in. Then it boots up every 3 seconds. So I openend up my phone and I saw the following was missing:
Is this the problem?
Or should I replace my U2 ic?
Hope anyone can help me out!
Thanks in advance!
Thomas.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Thomas, yes that is a part that could be the cause for it. It is reference designator FL10 which is a 120OHM 210MA fixed inductor in a 01005 package. Go with that first. It's a lot easier to replace that one than U2. Make sure that you clean your board properly with isopropyl alcohol etc. while you are replacing the inductor.
Punteggio 0
Commenti:
Really, you are so great! Thanks! One last question, think you hear this one a lot, where can i find and order the 120 OHM 210MA fixed inductor?
Again thank you very much!
da
Of all places, you can get it from Amazon Of course, my choice would be this one.
da
Aggiungi la tua risposta
Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 448
