Core I'm not really sure about
I'm not really sure about the mother board and the capabilities of the computer at all.
The computer will not boot.
Questa è una buona domanda?
Resetting NVRAM
1. Shut down your Mac.
2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
3. Turn on your Mac.
4. Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
5. Hold these keys until the computer restarts and you hear the startup sound for a second time.
6. Release the keys.
After resetting NVRAM, you may need to reconfigure settings for speaker volume, screen resolution, startup disk selection, and time zone information.
If issues related to these features continue on a desktop Mac (like an iMac, Mac mini or Mac Pro), its logic board battery may need to be replaced. The logic board battery on desktop computers helps retain NVRAM settings when your Mac is unplugged. You can take your Mac to an Apple Store or Apple Authorized Service Provider to replace the battery on the logic board.
If you are still having problems after resetting the NVRAM, try this
1. Press Command-Option-Escape to force quit any application that is not responding.
2. Put your Mac to sleep by clicking the Apple () menu and choosing Sleep. Wake the computer after it has gone to sleep.
3. Restart your Mac by choosing Restart from the Apple menu.
4. Shut down your Mac by choosing Shut Down from the Apple menu.
5. If your Mac isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note that you'll lose any unsaved work in any open applications.
If you're using a Mac notebook and it's having issues related to power or the battery:
1. Unplug the power adapter from your Mac and from the wall power socket for several seconds.
2. Shutdown your Mac.
3. Physically remove and re-insert the battery (if it's removable)
4. Restart your computer.
If the issue still isn't resolved after following these steps, you might need to reset the SMC.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 67
3 Commenti
Can you locate your serial number on the bottom of your system. We need the last four digits, then we can identify your system.
da Dan
If it is pre 2008 machine, remove the battery and look in the compartment for the number.
da mayer
When you say it will not boot do you get any reaction when you turn the system on? Does the display light up? are you seeing anything on the screen (you may need to point a flashlight though the back logo)?
da Dan
