Salta al contenuto principale
How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
Punteggio 2
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
http://cgi.ebay.com/Apple-PowerBook-G4-1...
Punteggio 2
2 Commenti:
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
da
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
da
You would need to replace the upper case.
Punteggio 1
Aggiungi la tua risposta
Jackson Carrie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,192
