Salta al contenuto principale
An optical disc drive released April 2009, identified by model number iHAS324.
Domanda Chiusa
My disk tray will not stay open, what can I do?
Whenever I press the eject button, the disk tray opens then immediately closes. I can't get my disk in the tray fast enough, because it will not stay open. I know the disk tray belt and motor are working fine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
If the disk tray will not open and remain open, you may need to replace the eject button.
Punteggio 0
Risposta Più Utile
It won't read, won't stay open, and won't eject. It's probably 5 years old. CDW sells it for $19.99. If blowing it out with compressed air doesn't fix it, you have to ask how much your time is worth.
http://www.cdw.com/shop/products/LiteOn-...
Punteggio 1
1 Commento:
See if there is a small hole above the eject button. Use a straightened out paper clip inserted into the hole to manually eject the tray. This takes a bit of force sometimes. Sorry, I just realized that this is a school project question.
da
Questa risposta era destinata originariamente a un'altra domanda.
There may be a disk jammed in the device. You can try and manually open the drive but be careful as the tray may break. Or you might have to take apart the device and replace the disk tray belt.
Punteggio 0
No No No,
Drive Belt slipping,
I could not find a replacement.
Lite-On is known for this on quite a few of their drives.
Various remedies online are:
1. place belt in boiling water (supposed to shrink belt).
2. use drive belt conditioner.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 28
Tutti i Tempi: 416
