Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
also have the error 53
I also have the error 53
My screen was never replaced- I DID replaced the flex cable-
Phone was dropped in water but no signs of corrosion- even the liquid sensors did not change color-
After the phone was dropped- i let the phone "dry out" I did not remover the battery BUT the phone worked fine for over a month with no lasting effects of the water-
The issue started when I "erased all content" through the phone- it locked up so I figured I would just update it-
This is where error 53 happened- it was bout 5-% done when the error popped up---
Nothing in the phone was corroded – I changed the flex cable because I read that was a common issue- but I didn’t fix mine…
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds very similar to my error 53 issue.
I swapped out a new LCD Shield plate which
had the home button cable and was able to then
restore. I assume that's what you also replaced
when you are talking about the flex cable? If you
have perhaps its related to the home button / Touch ID
assembly which can't be replaced to restore the device.
Punteggio 1
3 Commenti:
Yes put your original home button assembly back
into the new screen & you should be fine.
da
My phone is all original- straight from a sealed box from At&T- This error occurred out of nowhere while trying to upgrade from 8.1.2 to 8.2. I took the phone to a tech you tried to restore it using another iphone 6 screen (with home button assembly in tact) Still error 53 at 50%..
This is so frustrating and seems to be pretty common
da
I know how frustrating that is! Been there
before! You need to use the original home button
tho. It won't restore with a new screen that has a
different home button. Try that. It's possible while
there was no water damage that there might
have been to affect either the home button assembly
or the home button cable.
For me replacing the home button cable fixed
my error 53. That's where the issues I believe
are for you. My home button worked fine like yours
till I did a restore & it locked up on the error 53.
da
Aggiungi la tua risposta
Sophee24 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 643
