Is there any Sata to mSata adapter?
Hi,
does anyone know where to get an adapter cable - from Sata to mSata?
So that i can connect any normal sata SSD to the internal mSata port?
Questa è una buona domanda?
Hi,
There is no room to support an adapter. Besides, the port on the logic board for the SSD is PCIe and a custom ribbon connector.
If you are talking about the HD port that is a standard 2.5" SATA connector and the 2nd drive kit used in the older models will allow you to put in a second drive (HD or SSD) in a SSD only model.
i understand, but in general is there any adapter for it which i could use?
No internal adapter - Externally you could use the IFIXIT Universal adapter but that allows you to connect either a SATA or mSATA drive to the USB port of the system.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 377
