Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
The Azpen A909 tablet, released in 2011, has a 9-inch LCD touchscreen display and operates on the Google Android 4.4 system. Repair for this device requires prying tools, a small screwdriver, and possibly a soldering iron.
9 Domande Visualizza tutte
Why won't my tablet turn on?
Hello,
When I try to turn on my Azpen tablet, it doesn't power on. I had it on the charger all night, but still I have no response to pushing the power button. My warranty has expired so I am hoping I will not have to take it somewhere for fixing.
Is there anything I can do to try to do that doesn't require much experience in the world of tinkering with tablets?
Thanks for your time!
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Soluzione Prescelta
There are many possible causes for the issue your tablet is facing. It could be a result of a dead battery, a broken charger/port, or even something as simple as a frozen screen. It is very likely that the problem can be solved easily. Refer to the troubleshooting guide for more information.
Punteggio 4
Buy a friggin new one laimo
Punteggio 2
Find a hot water bottle to put on top of the battery ,as WHICH is the ionic liquid, the cold weather easily freeze the battery, battery can be removed if you use the universal rechargeyour, Flush enough, not be ok,next step to find the output voltage is larger than the original charger (not higher than 10V), it is impossible,then go to buy a bttery to change,it is not expensive.hope can help you.
Punteggio 1
Commenti:
i don't know if there is the battery on here www.iboxfix.com
da
you suck I have a girlfriend but she is not going to be able to make it to the meeting tonight but I will get it to you tomorrow morning at the latest and greatest thing to do is to inform you that I have a new phone and I don't want to be a part of the team and I will get back to you on that one and the other is a little bit of a little
Punteggio 0
Aggiungi la tua risposta
Zachary Kroll sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 5,294
