Salta al contenuto principale
The HP Envy dv7 is a Windows 8 laptop that features a 17.3-inch screen.
16 Domande Visualizza tutte
Why won't my laptop charge?
My HP ENVY dv7 won't charge. I have taken out the battery, used multiple wall sockets, used two different cords and it will not charge. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Does it turn on when connected to power cord without the battery?
Punteggio 1
1 Commento:
If it does it sounds like a defective battery and seeing as your laptop is relatively new it may still be under warranty.
da
I also found out what the solution is!
On the mainboard (near the power connector) is a TI chip (Texas Instruments), identified as BQ 24740. (Texas Intruments part # BQ24740)
This is the battery loader and power control chip.
It is easily destroyed by a weak and flimsy external power supply, like what is delivered with HP products.
The DE-soldering and soldering is tricky, because it is a QFN package, and very small.
It solved my problem for just $ 8for the chip and $60 for a local shop to install
Punteggio 0
Aggiungi la tua risposta
Nick Franz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 527
