Salta al contenuto principale
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
I can't charge my iPad
When I connect the iPad to the power adapter it appears the green battery with the lightning mark but the i pad won't charge
I tried the restor
I tried another power adapter
I tried another cable
I tried hold the two buttons
But the issue wasn't solved
Questa è una buona domanda?
Punteggio 3
1 Commento
does the cable go in far enough inside the dock?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Firstly,iPad Air Battery is particularly sensitive to temperature, There are a lot of friends would like to protect it with the Case. But when the weather is hot in the summer, may it will lead to dissipating heat is not good and it failure. So please take it out.
Punteggio 1
Aggiungi la tua risposta
Sohaib Khelfi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,222
