Salta al contenuto principale
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
New black ZIF Connectors on motherboard
What are those new ZIF connectors called? Old ZIF had a white tab and locked into place. these new ones are black and doesnt go all the way up or lock back down. What am I doing wrong? This *New* 3DS motherboard appears to be a mix of old ZIF and new ZIF connectors. the black ZIF connectors are for the Homebutton and LCD brightness and others.
Questa è una buona domanda?
Punteggio 3
2 Commenti
Circle in Red to see what I'm talking about.
http://imgur.com/N9x3kRk
da
@simonpoon could be faulty, had these replaced on an older 3ds
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
For those in the future it is the JAE FA1004SA1-R8000:
https://www.digikey.com/products/en?keyw...
Punteggio 6
4 Commenti:
How hard it is to weld it into the motherboard ?
da
There are 8 pins to connect per connector. I heat shielded the board and heated the board on the underside with a hot air gun to remove the old connectors. Then tinned the contacts, put the new piece down and heated from the underside again. After the new piece had been soldered to the board I took the soldering iron to the pins on the top side using 0.03" dia solder. I also heated the top contacts by holding the soldering iron to those pins, perhaps a bit overkill but they are soldered on there well now. Be sure to clean any flux residue with a soft brush and rubbing alcohol being careful not to lift the connectors. Solder paste would have made the job much easier. This took me about 2 hours to do 3.
da
i am working on one now and the link you gave has an option for 3 different part numbers. how would i know im gettnig the right one
da
MY HERo, saved me from a 20$ ebay ripoff zif
da
They're still flat cable ZIF connectors, they just don't have locks. You shouldn't need to pry them up to remove the cable -- at least I didn't.
Punteggio 0
What I did was take the cable out of the connector, place it back roughly where it's supposed to go, then apply a small amount of pressure to the BACK of the connector, opposite of where the cable goes in, where the 4 connects look like a hinge of sorts. Apply just enough pressure to see the connector bend down to where it's supposed to go. Pressing on the front of the connector, where the cable goes in, didn't do much for me. Still can't get my MIC to work... Still, light sensor and home button work excellently.
Punteggio 0
1 Commento:
Yeah I tried that, the only way for me to get it working was for me to send the device to Nintendo to replace the systemboard. It will work if I use my thumb to apply pressure on the ZIP connector while the device is on which is how I figure its wasn't "locked" all the way down but it was probably just a faulty ZIP connectors.
da
Aggiungi la tua risposta
Simon Poon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 71
Tutti i Tempi: 3,825
