Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1232 Domande Visualizza tutte
Domanda Chiusa
Is this part sold?
The actual home button circuit inside my phone with the 2 little gold things on it needs to be replaced is it possible to buy and replace this part?
Update
My ribbon is fine I have already replaced it. It is the two little gold prongs I was talking about. So if I replace the charging port , it wil come with that new piece with the gold prongs?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Yes, the home button ribbon can be repaired. Here is the link to the part: iPhone 5c Home Button Ribbon Cable.
The ribbon cable is fairly easy to replace if you know what you are doing. I suggest also following the repair guide when replacing the ribbon to minimize any further damage. It can also be found here: Sostituzione cavo a nastro del pulsante home dell'iPhone 5c.
You may also want to purchase this part to help you open your phone safely and avoid damaging any other components in the phone itself: iSclack.
Hope this helps and please keep us updated on your progress.
Immagine iPhone 5c Home Button Ribbon Cable
Prodotto
Immagine iSclack
Prodotto
iSclack
$24.99
Punteggio 1
If a new home button doesn't work then it will be your charge port that's faulty because it give the home button it's power through two hold prongs that are attached to it phone will still charge fine but it's the gold prongs on it that will be damaged
Punteggio 1
1 Commento:
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 64
