Salta al contenuto principale
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
Why isn't my camera's screen showing pictures/images?
When I turn on my camera and the light is on which shows it is powered on, nothing appears on my screen when I aim to shoot. I am not in a dark environment, there is nothing on the outside lens, and I have never had this problem before. What can I do to fix this and what could be wrong?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
  • The screen is cracked or water damaged. The screen may need to be replaced.
  • The wires that connect to the screen are faulty or disconnected. Disassemble the camera to reconnect the wires or determine other types of internal issues.
Punteggio 1
Hi, it's possible that your screen may be damaged or there's an internal issue. There's a replacement guide for this if you're interested: Canon PowerShot G12 LCD Screen Replacement
Punteggio 0
It's a common failure, a mechanical problem on the lens shutter :-(
Punteggio 0
1 Commento:
How do I fix it
da
Aggiungi la tua risposta
Nathan Meuwissen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,790
