Salta al contenuto principale
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Recently, the CPU fan started running at full speed. What is wrong?
The CPU/Video fan runs slow at startup, and gets ridiculously fast and loud after a few minutes.
I disassembled the computer to remove 3~4 years of dust on the heat pipe fins, but the problem remains.
It is the nVidia logic board GPU that is running at 160 deg F. It has the CPU/GPU fan running at a full 3600 RPM. Is this in spec or am I going to need to try to re-seat the heat pipes to get a better thermal connection?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
did you replace the thermal paste on the cpu/gpu?
i had a few macbooks with heat problems, the paste was hard and almost useless - in other cases, there was way too much of that stuff on the chip's (original apple!).
replacing it is a must!!
Punteggio 5
5 Commenti:
+ although nick recommended the thermal paste first, I'm gonna uptick ya. LMAO
da
no, he edited it in his answer after i wrote it - as always (check the history - but i think he will delete his post soon - also as always)
da
you are aware that everybody can see the "edited by" and of course the history of a posting.
da
@ Markus...I was being sarcastic. LOL
da
;-) and nick, it's not that "I" have a copyright on the stuff i'm writing. but it's lame to edit the stuff of an answer in the own answer - only to - yeah - only to what ? get a better reputation score? it's like the deleting stuff that you always do - i delete my answers if the worst case happens and mayer, majesty and answer at the same time - like a few minutes ago.
da
Try downloading a demo of iStat menubar.
Then you will get a good look into the CPU processes and temperatures in your iMac.
heres the program
Punteggio 1
2 Commenti:
If you'd given a link you'd have gotten an upvote.
da
i edited this with a link
da
You could also try Activity Monitor, which is included with OS X.
Punteggio 0
Aggiungi la tua risposta
Jeff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,581
