Salta al contenuto principale
The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
Questa è una buona domanda?
Punteggio 13
3 Commenti
I have a tablet and it turns on and you can hear everything but you can't see anything
da
I have this problem
da
my lenovo won t open
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
If it does turn on it pops up Reboot and some other stuff too
Punteggio 1
lenovo tab not turning on
Punteggio 1
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
Punteggio 1
Check the battery. I opened mine and the battery didn´t charge anymore
Punteggio 1
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
Punteggio 0
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
Punteggio 0
Aggiungi la tua risposta
sandy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,546
