Salta al contenuto principale
Replaced my hard drive with SSHD and now it won't turn on.
My old 2007 A1229 17" MacBook Pro had a hard drive failire so i replaced it with a Seagate 1T SSHD. Now it will not turn on. Only the sleep light blinks 3 times, pauses and repeats. Is there something I am missing? I have an external drive with time machine but the computer won't even come on.
Questa è una buona domanda?
Punteggio 1
1 Commento
How did you install the HD? Did you clone it from your old HD or just drop it in?
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Try re-seating the RAM.
Punteggio 2
Be sure to check the cable that connects the drive to the logic board. It could have come disconnected or even torn during the hard drive replacement procedure. If I remember right, this model's cable is glued down onto the original hard drive, making it that much more difficult to remove safely. Good luck.
Punteggio 0
Your GPU died! These machines are ticking time bombs, and yours went off. I am sorry to hear this. :-(
Punteggio 0
Aggiungi la tua risposta
Courtney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 170
