Salta al contenuto principale
Guide di riparazione e informazioni per il disassemblaggio per i laptop prodotti da ASUS.
2523 Domande Visualizza tutte
How to make sure LCD cable doesn't become loose over time?
Hi all,
I have a ASUS ROG G550JK laptop, which has an annoying problem. The screen does flicker randomly from time to time, by I mean randomly, it flickers for a frame only, and then doesn't flicker for 5-10 mins etc. then flickers randomly for one frame again. One thing to note is this doesn't happen on an external screen, only at internal laptop display.
I have opened the laptop and reseated the LCD cable on the motherboard, then for 2-3 days it didn't flicker but then it started again, figured it become loose again, I did the same process again, and it didn't flickered for 2-3 days but now it's flickering again.
What can I do to make sure the cable doesn't become loose in time? I thought I can try to fix it with some electrical band. What are your opinions? Thank you very much for your help.
Questa è una buona domanda?
Punteggio 2
2 Commenti
My screen is completely black, before it went that way it flickered a couple times. I have reset the connection several times but I still have not had any luck bringing it back to life. Do I have the same problem? I didnt have any of the tools that you suggested on me but I will make sure I get them if needed. Thanks for reading this I hope it can be easily fixed.
da
My screen turned black a while ago like 2 years ago but from time to time when I put preasure sometimes in the screen hinge my laptop screen comes on so I'm wondering if it's a lcd loose cable and if I could diy it and my laptop is hp brand
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would recommend cleaning the connections gently with a brush and a little isopropyl alcohol 99% . Making sure the laptop is unplugged with battery removed. Once you have reconnected the lcd to the board i would use kapton tape to keep the connector in place.The connection on the rear of the lcd could also be the culprit .
Punteggio 0
1 Commento:
It'll be the connection to the motherboard. It's a known problem with the G550JK. Still looking for a permanent fix
da
Aggiungi la tua risposta
Deniz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,978
