MacBook Pro battery when watching online video (youtube or netflix)
I bought a new Macbook Pro 13" Mid 2009 Battery from iFix last week. it was a fairly easy process to replace the battery.
However, I was expecting to be blown away by the new battery after having used my old one for about 5 years, but the new battery only gives me 2 hours of online video viewing, and 3.5 - 4 hours of web surfing!!
Firstly, is that normal? Or did I get a lemon?
Secondly, If it is normal, can someone tell me how to increase the battery performance? I'm currently on Yosemite, and don't mind switching back to Mavericks.
And, by the way, I already did the SMC reset and calibrated the battery.
More specs:
MacBook Pro Mid 2009
8 GB ram (4 GB X 2 1066 MT/s)
Samsung SSD 500 GB
Thank you in advance.
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would start by making sure your running the latest version of Adobe Flash (64bit version). Flash is a hog! The newer versions are better but still way to heavy CPU & battery) given what others are able to do.
How much space is free on your SSD? You should have about 1/3 free. You could try upping the RAM as that will help remove the need to use viral memory on the disk (SSD).
Are you using TRIM services?
Punteggio 1
Commenti:
Thanks much for your response..
So, I have the latest version of flash installed.
I have a 500GB SSD out of which only 80 GB is used, (Yosemite fresh install + office and some minor apps).
I already have 8 GB of ram, which is the recommended max for this laptop..
And, yes, i've enabled TRIM as soon as I installed Yosemite..
Don't have a clue of whats going on. I'll call iFixit tomorrow.. I'm starting to think that the battery i received was defective..
da
Aggiungi la tua risposta
Sundeep S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 237
