Salta al contenuto principale
How to identify the model of MBAir? Is it 2008 or 2009?
I need to replace my LCD. The seller requires to identify the model whether it is 2008 or 2009? How to identify it? All I have from the hardware test utility is MacBookAir 2.1.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
MacBookAir2,1 is a mid2009 model. I have the same one.
http://grab.by/5dEh
Punteggio 1
1 Commento:
+ for experience
da
There are a couple tools at your disposal. First is the iFixit Identify Your Mac Tool, or you can also use EveryMac. Either one should have the information you're looking for.
Punteggio 0
One way to check is to see what kind of display output port you have in your flip down tray.
  • The early 2008 model came with a micro-dvi connection (I have this model)
  • The late 2008/early 2009 to present have the Mini Display port.
If you have a output display adapter you can hook it up to an external display and check the system configuration.
Punteggio 0
Aggiungi la tua risposta
Vladimir Dobrokhodov sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,033
