Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Domande Visualizza tutte
I like to know how to turn on my MacBook air without keyboard
hello I am very proud of this website I looked everywhere I have not found I like to know how to turn on my macbook air model A1370 mid 2011 without keyboard
Questa è una buona domanda?
Punteggio 3
1 Commento
You are looking for the power pads on the A1370?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
men, use the power on pads. Bridging those two pads should power on your MBA unless there are other issues with it.
Punteggio 8
1 Commento:
This was super helpful. Thank you ❤️
da
Hey men
What is probably the easiest way to do this, would really be just to remove the MacBook’s battery. If the battery isn’t present the power button becomes disabled because your power runs from the charging brick the MacBook came with. So if you connect the MagSafe connector, the Mac turns on instantly. If you disconnect it the MacBook kills because there is no power.
Hope this helps!!
Punteggio 2
Aggiungi la tua risposta
men sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,900
