Do I need to replace my motherboard?
Hi,
I have Toshiba t135 laptop, when I charge the battery, the LED is lighting so its not the problem, when I press the power button, the LED light comes on but nothing happen, and no fan spinning, no hard drive sound, no beep sound just a quick blink light of power button and the LED lights.
Questa è una buona domanda?
3 Commenti
Makely, start by doing this Turn off the laptop then remove the battery and the charger.
Connect the charger back leaving the battery out.
If it is just a simple power glitch then, it will be resolved. Let us know what happens.
da oldturkey03
Thank you for the respond oldturkey03, I tried it already but same thing happen. What should I do with this?
da Makely
I removed my machines C-mos battery? Then return it to its rightful place. Yes, th perfect solution nd it worked.
Ones my pieced my machine together, I powered it back on. There weren’t any blinking led’s, with my screen back on. I got a display message something about; your c-mos battery is removed, blah blah. Ignored that nd entered F2, 4 setup nd configured my dates Oh, nd make sure your machines battery is having power for when you turn it on, nd lastly make sure your Critical Battery Wake-up setting is disabled in th C-mos setup. That should come as a recommendation, Yawl ar welcome.
da frankduffey
