L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di estrazione. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3944 Domande Visualizza tutte
logic board grounding brackets?
will not haveing the grounding bracket installed prevent charging the phone? or any other issues?? basically what's it important for.
Punteggio 0
Aggiungi un commento
Kit di riparazione per Android
Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
Acquista ora
Acquista ora
3 Risposte
Chosen Solution
I just got one in that had that bracket missing. The phone would only boot half way thru with out it. It helps hold the connectors in tight. Once I replaced it the phone worked fine. See if this part in step 11 & 12 is what you are talking about: Sostituzione della scheda logica dell'iPhone 5s
Punteggio 2
You have to specify which one.
Some of those brackets are not just for grounding, they actually conduct RF signals. If those brackets are missing, you will lose reception.
Punteggio 1
Should be fine, If you have any doubt you could insulate with some electrical tape to make sure there is no short between the motherboard/housing/underside of screen.
Punteggio 0
Commenti:
i think you misunderstand me, there is a bracket between the motherboard and housing, connecting/grounding it, this part is missing on my phone and i want to know if thats why it won't charge? because the battery is fine and the flex cable is fine.
by
Add your answer
jai will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,263
