Salta al contenuto principale
The Motorola Q is a Windows Mobile smartphone with similar styling to Motorola's immensely popular RAZR.
Recharging port is not connecting, how to repair?
Sometimes holding the recharging plug at a certain angle will charge, but it will not stay. Can this be repaired?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
The moto q is charged via the usb port, the port could normally repaired - but that involves soldering
you wrote that it works when you hold it in a certain angle - sounds ok - but it isn't!
the more you bent it, the more damage could be done
is used a picture from the teardown to show you this:
to fix it, you have to resolder the broken parts - and it would be a good idea to check the 5 usb contacts to the main board - they break if they were bent to often
if the picture is to small, use the huge one
Punteggio 2
Try cleaning the lint out of the charge port.I had same problem ,so i took a pin and picked an amazing amount of lint out. Know it works like new.
Punteggio 0
Aggiungi la tua risposta
Jerry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,139
