Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore.
695 Domande Visualizza tutte
water coming in to the machine when it is not being used
When I am not using the washing machine, it slowly fills with water.
So everytime I need to wash clothes ,I have to drain the machine. It also makes the machine smell bad. How can I solve this problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Replace your water fill valve or take it apart , remove debris and clean with a product such as CLR. The chances are that the solenoids are good on the fill valve. Most likely it is clogged slightly open with calcium. lime or debris allowing water to trickle through. If you are on a well it is most likely sand or dirt holding the cold water valve open. Clean it out or replace the valve. Then replace the washers to the fill valve(s) with screened washers (where the water hoses attach)to prevent this from happening again. Instructions for removing/replacing valve can be found inthis video. Good Luck!
Punteggio 1
Risposta Più Utile
Water Inlet Valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Other Causes and Conditions
Low Water Pressure from House Supply
If the washer fills very slowly, the water pressure from the house might be too low. If the water inlet valve isn't leaking and there are no other symptoms this problem does not need to be corrected.
Punteggio 1
Aggiungi la tua risposta
deb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 251
