How to get replacement screen to sit flat and secure?
My replacement midboard does not have the little rubber pads around it like the original. Is this ok? What about the larger rubber strip, in your guide it says to replace it if it is present. Is it not present on all ipad frames? I am asking this because when I go to replace the digitizer, it bows out slightly on the digitizer cable side, causing the ipad to behave oddly. How do I get the new frame to sit securely and flat? Thanks.
Questa è una buona domanda?
I noticed you never got an answer to this. Are you still having this problem?
da originalmachead
