iPhone will not turn on
So I replaced the screen in my iPhone 5, and now the phone will not turn on. I did not touch the logic board, only the parts needed to fix the screen. What could've caused this? How do I fix it?
Questa è una buona domanda?
Are you sure the phone is "dead/not turning on?" May be the phone is turning ON but the screen isn't.
Charge the iPhone for 20 minutes using a known good cable and charge, to make sure the battery is holding a charge, then connect it to a computer. Is it recognized by iTunes?
- If not, you phone could be "dead" but not lost. Don't panic just yet. Let us know and we'll figure out what's next.
- If yes, iTunes sees the device, then here are some of the most common issues:
A/ Phone needs power cycling and/or rebooting:
A-1/ Reboot: press and hold home button + power button for ~12 seconds. Try to restart. Does it turn on?
A-2/ Power cycle your phone: lift the screen, disconnect the battery connector (DON'T try to remove the battery), press and hold power button for ~15 seconds. Reconnect and test. If screen starts, reset the time and date then reboot again.
B/ Connectors need cleaning and/or reseating:
Disconnect the screen from the phone, clean the connectors on the board (and the screen cables, but gently not to damage them or splash the screen) using a cotton swab dipped in 90%+ isopropyl alcohol, dry, reseat the screen cables gently but making sure they are firmly connected. Restart and test.
C/ Screen assembly is dead: because it came defective or you pulled on the screen cables while installing assembly. Try the old screen back, or a new known good screen, and see if it solves the issue.
D/ Pry damage: if you reach this point without having solved the issue, let us know, so I can point you to the location on the board that you need to examine for potential pry damage.
Good luck, and let us know what you find out.
Thank you so much, I tried a few of these and one of them worked. Thank you
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 115
