Salta al contenuto principale
The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
21 Domande Visualizza tutte
Why the screen show White?
My Acer got white!! I was just playing some music, then i lay it down on the couch and went for something. When i returned the screen has got white and there was a crack in The middle, (not really, but it looked like an inside one ). But there was a black spot too. I turned it off and it turned black. Then i again turn on, but the screen appears as white ,black spot,and crack as it was. I tried to pull the notification bar. A sketch of bar appears but no icons or nothing. Help me please.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Did you sit on your tablet? Or did it drop when you were away? Anyway, the fact is your tab lcd display was damaged.
Punteggio 2
2 Commenti:
SO, should i have to change the lcd screen? And my sister was there too, according to her, the tablet was there laying, and it didnt even fall. She haven't lied. However, what to do with the tablet, and how to fix it??
da
You mentioned that your tablet had cracks, spots and blank screen, these are all hardware issues not software issues. A replacement display can fix it. If you'd like to DIY repair it, this is the part: http://www.etradesupply.com/acer-iconia-... and this is the guide Acer Iconia B1-A71 LCD Display Replacement
da
I have the same problem but my screen was already cracked
Punteggio 0
Aggiungi la tua risposta
Asad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,419
