Salta al contenuto principale
La Golf MK4 venne introdotta per la prima volta in agosto del 1997, seguita da una versione berlina (VW Bora o, in Nord America, di nuovo VW Jetta) in agosto del 1998 e una nuova Golf Variant (station wagon) a Marzo del 1999.
35 Domande Visualizza tutte
Domanda Chiusa
VW is sputtering in idle and in low gears?
I recently took my 2005 GTI to the local mechanic - I know the topic is up until 2004 golfs, but I don't think there should be much of a difference when you read the rest - So anyway, they replaced an O2 sensor, cleaned out my Mass airflow sensor, replaced the crank sensor and fixed a problem with the axle on the front passenger side and got an oil change. When I picked it up, the mechanic told me the spark plugs needed to be dealt with because there was wet gasoline on the plugs. Now it sputters a decent amount at idle (a shaking back and fourth at a red light that lasts longer than 15-20 seconds) and then upon turning green it sputters quite a bit; having power, then losing it. Kind of seems like breathing in and out really fast if that makes any sense. So he told me to go drive it on the highway for a while to dry it out. The thing is, this wasn't happening at all before. The idle was fine, it didn't sputter like this. There was some "laggy" gear shifting, which the crank sensor was suppose to take care of.
I suppose my question is, do you think there was something done wrong with the car? I haven't yet had the chance to take it on the highway for an extended amount of time.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sounds like they might have taken your plugs out to look at them and possibly damaged one or more in the process of checking. Might have cracked the porcelain or hit the head changing the gap. Another possibility is while cleaning your MAF sensor they might have touched the pins, getting oil, grease or dirt in the contacts. If its none of those are the culprit possibly look at your fuel filter, might need replaced.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,028
