Salta al contenuto principale
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Domande Visualizza tutte
Domanda Chiusa
Apple LED Cinema Display does not display
Hi all,
Apple LED Cinema Display 24" is not displaying anything.. i have open it and release there is power on board and fan is also working... i reattached all the interior cables but still nothing is displaying..... what is the cause and what do i need to change (parts)...
please help..
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
check the fuse on the lcd panel's logic board.
Punteggio 0
1 Commento:
Hi how do you check the fuse on the lcd panel's logic board
da
dissasamble it at first! then check the fuse and if it does not shows continuity its damaged... change it cause if its damaged the main board has a self-protection that does not allow the pass of current to the display that way it wont damage the screen too!
Punteggio 0
2 Commenti:
Hallo, can you explain us where is the fuse? is it on the Logic Board? It is possible to make a picture of the position of the fuse?
I Check the voltage, all is ok, just TP 81 and TP 12 get no power when the Display cable is plugged.
Thank you very in advance!!!
da
where is the fuse and how to replace it?
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 6,700
