How to clean glue off Logic Board LED Connection?
Hi folks,
I wanted to stick the fallen rubber foot of my Macbook Pro with glue but unfortunately the glue leaked in and affected my LED Display connection.
I realised it in 2-3 minutes after seeing my screen flicker. I immediately cleaned the glue off the connection with microfiber cloth.
The flickering seems to go away or at least way better than the beginning but when I move the laptop i happens sometimes. I'm sure there's some remnants of glue between the pins and it's causing the problem.
Do you guys have a recommendation how to clean it completely? would rubbing alcohol with a soft tooth-brush work?
Questa è una buona domanda?
3 Commenti
Can you tell us what the glue was (brand and kind of glue)
da Dan
Hello,
I know it's supid but it was basically a wood glue (Ponal Wasserfest)
Here's the link for it.
http://www.ponal.de/Ponal-Wasserfest.704...
Was a terrible idea but i need help :/
da bigboss
Looks like the Leim is supposed to be water soluble. You may be in for a bit of a mess. I'd try a clean it up with a bit of heat from a hair dryer to soften it, then some sterile water followed by high grade of isopropyl alcohol to disperse the water.
da oldturkey03
