Replaced LCD, still not working
Recently i dropped my iPhone in a bar and cracked the screen. For some reason the LCD wasnt working either so i had assumed that the LCD had broken too. Either way i replaced both the digitizer and the LCD panel. For some reason, this still didnt work when i had plugged it in
I assumed this might be because i removed and replaced the screen once it was still on. Somewhere it suggested removing the battery to reset it, which i did, running the battery first before reopening. but still no avail.
One other point was that the phone cracked (badly) around the top of the lcd, and that the LCD connector comes loose very easily, even when firmly snapped in.
The phone still works fine, the vibrate/ring switch still makes it viabrate and the phone manages to onnect with itunes still.
Any ideas? im considering buying a full front assembly on ebay to see if that works as it might be a faulty display to start with.
Questa è una buona domanda?
Ok so a new LCD seemed to fix it. It slipped right in and clicked into place so luckily there was nothing wrong on the logic board. However this new screen is pretty yellow.
da TimE
way to much yellow or the "regular" iPhone 3G yellow problem ??
da markus weiher
