Salta al contenuto principale
The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Domande Visualizza tutte
Domanda Chiusa
Computer recognizes drive but I can't erase or initialize
Hello, I recently purchased a 3 TB Toshiba internal hard drive that I want to use as a second drive in my Duel Mac 2Ghz PowerPC G5. The computer recognizes the drive but I cannot erase or initialize the drive. I'm running Mac OS 10.4.11. Any help would be great, thanks!
Tym
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
More than likely you are having a SATA problem. The HD you recently purchased may promise to be backward compatible or automagically self limiting (and should be) but I belive it's not working.
Your ID fits 5 different versions of the G5 box, but all use SATA I HD's.
You may be able to manually set the SATA speed of the drive. If not you may want to try a different SATA cable or need to find a different drive.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 2
1 Commento:
I think the problem is my computer uses ATA, not SATA, for the internal hard drives.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 111
