How fix loose charging port
Loose Charge port on Apple Mac Book Pro
Questa è una buona domanda?
It sounds like the mounting screws internally have loosed up. But without some guidance on which model you have I can't offer you more.
Are you up to fixing your own system here? Do you have the needed tools? You may want to start there.
OK, Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement upto Step 2, then look where the MagSafe connector is you should see two screws which holds the connector block (DC-In board).
If the screws are tight, then the whole DC-In Board unit will need to be replaced.
Follow the guide though or you may want to bring it to someone with better skills. This is a bit tricky repair as you need to fully remove the logic board to gain access to the DC-In Board connectors connection to the logic board is underneath.
Here's a good source for tools: IFIXIT Store
Thanks for your response. Last three letters of serial number : 66D
I have no specific tools, apart from a few "Phillips" screwdrivers.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 10,696
2 Commenti
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
da Dan
2.26 GHz Core 2 Duo (P7550*)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MB990LL/A Model No: A1278 (EMC 2326*)
Subfamily: Mid-2009 13" Model ID: MacBookPro5,5
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
da oldturkey03
