Salta al contenuto principale
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 Domande Visualizza tutte
gps causes tablet shutdown, ss galaxy tab 4
Every time I turn on gps app it works. It will run for a few minutes, then the tablet will go into a restart. I have tried about 10 different apps, and even bought anew app for $20, with Tom Tom software, but still had the same problem. I have tried all I could find in setting, but be unable to fix it.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Did you buy the tablet from a direct seller or did you buy it used I would recommend reseting the device by turning it off. Then holding the volume up button and then the power button. The screen then will turn on then using the volume buttons select the reset and press the power button to reset it
Punteggio 2
1 Commento:
Bought new from barns and noble, as their new nook. The gps was the first thing tried on the fresh tablet.
da
Aggiungi la tua risposta
bluesatrin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 508
