Does Digitizer replacement affect smart cover sensor?
I got my ipad air digitizer broken , i was about to replace it but i've been told that replacement would affect smart cover awake/sleep sensor . Is that true ?
Questa è una buona domanda?
It does affect that function for the iPad Mini if you use a "cheap" part.
It does not for the iPad Air unless you damage something during the repair.
However, make sure the bottom part of the digitizer is properly isolated with kapton tape (you can tell how it should be done by looking at the original digitizer once removed, to see how it is done).
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,523
5 Commenti
Did you solve this problem?
I have the same issue on an iPad Air wifi + cellulare 32GB.
Thanks, Mauro ju Macniaco
da Mauro Macniaco
Hi Mauro, I suggest that you post a question with your exact problem. Explain when and how it started, and if you did anything to try and solve it. This way, you will get better exposure and support for your question.
da Rany
I've replaced it , it's fully functioning
da Husain
Great, thanks for the update.
da Rany
This is the post with my exact problem:
<Lock function inoperative after screen replacement>.
Anyone can help me?
da Mauro Macniaco
