Why is my gun not cocking?
When I pull the cocking mechanism it has very little tension and the does not ready the gun for firing.
Questa è una buona domanda?
Broken Catch
The catch is an internal piece that catches the plunger when you $!^& the gun and releases it when you pull the trigger; the resulting rush of air is what propels the dart. As a relatively small part, made of thin plastic, the catch is particularly prone to wearing out after heavy use. Once broken, it must be replaced for the gun to function normally again.
Loose Catch Spring
The catch spring is a small, but vital part of the catching mechanism. It gives some of the tension necessary for the catch to latch on to the plunger. Without it, the catch will not spring back into place after firing the gun. If the spring is simply out of place, putting it back into position will correct the problem. if the spring is stretched from heavy use, it may be necessary to replace the spring. Many online sources report that a pen spring may successfully replace the catch spring.
See the Catch Spring Replacement Guide for more details.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 752
