My acer aspire showing nothing on screen
my acer aspire 5315 on for 5 second showing nothing on screen and then power off automatically....what would be problem its
Questa è una buona domanda?
This problem comes when your Processor or RAM are not working properly.so in this situation you need to check your processor and then you also need to clean your RAM and then you need to reinstall it.
While you are checking your processor. you need to make sure that your heat sink is properly connected and your CPU fan is working fine. if they are working fine then you need to remove your ram from your computer and then you need to clean it and install it .
Once you will do that then you need to restart your computer. then it should working fine.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 180
