How to get out offlashing box
when it start a little box in middle of screen with a ? then 2 faces
Questa è una buona domanda?
You have lost your boot volume. Either the Hardware (HD) or the software (System Folder) is damaged or missing. You should be able to boot from your install or hardware test CD and repair the drive software (directory) or reinstall the OS if there's space on the drive.
Of course if you're not careful you can lose all your data with an improper OS install.
What was the last thing you did, or happened right before this behavior initiated?
If this answer is acceptable please remember to return and mark it accepted.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 42
