Salta al contenuto principale
Repair information for the iMac G4.
130 Domande Visualizza tutte
Issue with screen - possible problem with inverter
If you switch on the iMac Mac (G4) and the screen comes on for a while, then flickers, and the backlight stops working resulting in a dark screen is this a problem with the inverter? If so, can I purchase this separately and install it? If so, how do I do this? Any help would be much appreciated!
Andrew
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The iMac g4 had some problems with scuffed cables inside the neck, but the inverter or the ccfl tubes are old - so they can also make some trouble.
i would first check the cables inside the nack - but it's not easy to open it. please read more about the whole disassembling process on: http://dremmeljunkie.blogspot.com - this guy made some heavy modding with his iMacs - but you only need the part with the neck ;-)
Punteggio 0
Aggiungi la tua risposta
andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,126
