Salta al contenuto principale
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
It won't start or turn on
Washer will not start
Kenmore 110
Questa è una buona domanda?
Punteggio 9
Aggiungi un commento
2 Risposte
Risposta Più Utile
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Check and make sure circuit feeding washer is live try plugging a working lamp into the plug with the washer to check
Update
If the lamp doese’t work go to the inside breaker panel and look for tripped breaker normally it will be a 15amp or 20 amp depending on how the circuit is run
Punteggio 1
Unplug the machine for 5 minutes to allow it to reset.
Punteggio 1
1 Commento:
Mine worked by resetting
da
Aggiungi la tua risposta
gene4unot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 8,081
